MrToolJunkie
- Jul 6, 2009
The key is to use the right saw for the application. There are different sizes because so many different needs. That is why Mafell has so many sizes - small trim saws that are light weight and huge timber frame saws that can cut large beams.
The 55/65/75/85 is the sweet spot in my mind for most general purpose cutting. If I were cutting 4x all day, then I would consider a Mafell MK130 saw that could handle that depth of cut. The bigger the saw the heavier and more unwieldly it gets - swinging 30 - 35 pounds all day with a large saw to cut 19mm sheet good does not make sense. Even my Mafell KSS80 is heavy for extended cutting sessions - it is absolutely the right saw to cut down 12/4 slabs, but I do not want to run it to cut sheet goods.
My TS75 is ideal for hardwood and 8/4 stock. It also works on sheet goods and it was my only track saw for the first 5-7 years of using Festool. It can even get a little heavy swinging it around all day and due to the blade and depth of cut, it is not ideally suited to working on the MFT with thinner stock where you need the right side anti-splinter insert (without making a modification). My TS55/TSC55/Mafell MT55, however, are all perfect for sheet goods and 6/4 and thinner stock. With the right blade, they all have adequate power for the task at hand. The MT55 is slightly more powerful than the TS75 FWIF.
HK saws are great at smaller trim work and working off the rail. The smaller Mafell saw (which I do not have) seems like a great trim saw and hardwood flooring type saw.
If I was limited to only one saw, then I would probably opt for the TS75 due to overall depth of cut and versatility. If I could only have one smaller saw, that would be a tough choice - I might actually just go with my TSC55 - great torque and convenience of being able to cut anywhere and not worry about outlets.
I have not been disappointed with any of my saw purchases - they all work as advertised and I get great results from each of them.
