I have been snooping around the forum for several years gathering useful data and tons of knowledge but this is my first post. I tried to find another post with the same problem and although I found many with similar issues none seemed to have the same cause.
I have a Festool OF 1400 router that I have been using for about a year and a half without any problems. I love the ease of setup and operation and of course the dust collection. I just recently decided to use it with a standard PC guide bushing and a template to router out a shallow mortise for some bed hardware. This is the first time using the guide bushing in this router.
When I installed the guide bushing I found two things. The first thing was that the bit was not perfect centered in the bushing. I found a couple of posts on this and I am confident that I can easily resolve that issue. The second issue that I found was that I have about 1/32nds slop in the entire guide bushing adapter plate. The movement is NOT in the bushing itself but rather where the plate connects to the base. There is a gap in the base plate on either side of that adapter plate tabs which allows movement side to side. I am sure that this can't be typical but I surprised that I haven't been able to find someone with the same problem. I have not taken the base apart to see if there are any adjustments but at first glance I did not see any obvious adjustment to tighten up the adapter plate.
Has anyone else run across this issue or am I the first? Is there a known solution?
Thanks for your help.
Andy
Andy
