Festool OF 1400EQ Circle Jig
timbertailor
Those of you who own this router know that a circle jig is not offered by the mfg for this model router.
Most of the aftermarket designs I looked at required the removal of the base plate.
Not something I wanted to have to do every time I wanted to cut circles. Not to mention, losing my chip collector duty.
This is a very simple design, easy to use, and cost little to nothing to build. The block of Bubinga and Maple was left over from a project my dad worked on. Thought I would repurpose it. It holds the DP track up 1/8"off the work surface to prevent drag while routing.
I found this 1/4" SS pin with a threaded end for the pivot rod. I cut key ways into the pins to tighten and loosen them. I have several lengths for different thickness of wood. I can micro adjust with the Rockler speed clamps, to an extent. The clamps also allow me to cut even the largest of circles by simply swapping out track length or cut circles in tight spaces.
The dual purpose track was left over from my assembly table and router table project.
Hope you like this idea.
