tjbnwi said:I’m 99.9% certain the 2200 edge guide fits the 1010.
Crazyraceguy said:Oh yeah, I forgot about that part. I mostly use the above the surface one and sometimes the chip deflector on edges, not as often as I should. It's not as simple as the OF1400.
In the US, the edge guide is an additional $50, the fine adjuster is another $33, the under mount dust fitting is $31. Now that you say that, I think the rods do come with the edge guide here too. I think I have 2 sets in one of the OF1010 Systainers. I bought an additional one, before the second OF1010, so I could use them both together on opposite sides. It worked out ok though, now there is a place to store it.
The guide stop for the FS rail does come with the OF1010, where it does not with the OF1400.
I just measured the guide rod diameters and spacing on my machines. The guide rods for the OF 2200 are 10mm in diameter and the guide rods for the OF 1010 are 8mm in diameter. The center to center distance between the guide rod ends when installed on the machines is 110mm for the OF 2200 and 107mm for the OF 1010. The edge guides are not interchangeable.tjbnwi said:I’m 99.9% certain the 2200 edge guide fits the 1010.
Crazyraceguy said:Why are the adapter rods so short on it?
tjbnwi said:1010 with the 2200 fence and the 1010 fence, use the 8mm rod.
[attachimg=2]
[attachimg=2]
Coen said:tjbnwi said:1010 with the 2200 fence and the 1010 fence, use the 8mm rod.
[attachimg=2]
[eek]
But I guess this bends the rods like half a mm each? Does it sit sturdy?
