Agreed. After discussions with a couple other members, this seems to be the only reasonable course of action at this point. The TS75 simply needs larger guide rails when cutting 4'x8' sheet goods than the two that TS55 owners are likely to have, which are the 1400mm and 2700mm units. The consensus is that though you can use the TS75 with the shorter tracks, it requires careful placement of the track lengthwise, careful plunging, and you might still be just a hair shy of runway at the end of the cut. As elimelech12 stated, kinda takes the "Faster. Easier. Smarter." right out of the tool.
The official line from Festool is only the saw gets recalled. You send them your Systainer with the contents complete, they send you the TS75 Systainer. So, you'd be stuck with two tracks that are a little too short.
Festool said I should contact the dealer and see if they'll refund the track. I'll hear back from the dealer tomorrow AM. Not that it matters. I know what I'm going to do.
Just can't say it on here, or a mysterious fellow will pop out and edit my post. Hi Shane! [smile]
[ Edited to remove the quote from a deleted post - Shane ] Hello.
