Festool this - Strawberry Tower project
I call not-it on making all those shelves :)
Thanks for the link, Tim. I have a couple of Gary's DVDs and have been a visitor to the jlc finish carpentry forum for a while.
Deciding if the jig should locate all the dadoes (comb shaped template) or if the workpiece should slide through the jig) is something I am debating now.
This project looks simple but it's not that easy.
Those dadoes are wicked little pieces of work, not only are they sloped but the sides are also angled. Unless you know someone with a  CNC, there is some hand work (176 cuts to be exact) or match up pair of dovetail for one side and chamfering bit for the other.
Building a jig for a table saw and cutting the dadoes with a dado set, set to the correct angle is probably the fastest way to do this but I don't think it would be the safest.
Wicked....
Tim
I will post some jig sketches soon. I'm hopeful there will be little hand tuning.
Sketchup has been very helpful. I made and learned from a lot of mistakes. I "made" uprights in the jig and learned I could put the stock in the wrong way, figured out how to design the jig to change over between left and right, etc.
I have followed this thread with an interest in the complex design (e.g. the geometry is crazzzy).
I don't want to derail the cool design discussion, but for lookie-loos interested in building one in a weekend... it just occurred to me that by sacrificing a little bit of the aesthetics (and save a ton of time) you could build the same functional piece, using square lumber (e.g. 4x4) for the corners of the pyramid.
This would remove the complicated elements of the compound-angled dadoes.  Just make the spacing marks on the pole.
Then you could use the Domino, MFT, some Qwas dogs, and using the guide rail as the Domino baseplate reference, with some stops on the guide rail... This would create an easily referenceable setup.  Mortise, mortise, slide.  Mortise, mortise, slide.
Or, you could still use sliding dovetails, but they wouldn't be compound angles.  The only angle would be to achieve the "tilt" of the slat.
Been working on possible jigs for a while this evening and running out of ideas. I'll e-mail the model to anyone who wants to bake their noodle a while thinking about how to do this efficiently ;p
The only feasible dado solution I see at the moment is something I think Tim had suggested. Come up with a jig setup that can hog out most of the material. (I am reasonably close to drawing something that could do this.) Then come back with maybe a Japanese pull saw and cut the angled shoulders. You could make some little guides that would help to angle the blade correctly. Still, that's 88 dadoes to tune up that way.
I'm seriously thinking about just using some Sipo dominoes for the job. (Since it's FOG, does that mean you won't say using Dominos is cheating?) I haven't thought much about the dominoes yet, but wonder whether assembly would be difficult. I guess I would glue up just one set of shelves at a time, possibly doing two opposing sides as separate assemblies first - then bringing together the two assemblies to complete the glue-up of the last two courses of shelves. I'd want to be careful not to distort the assembly - I was thinking ratchet straps may be a good way to pull the uprights tight against the shelf edges.
A couple renderings of the cutouts needed in the uprights -
Are there ~27 degree dovetail and chamfer bits out there that may work for the shoulders?
This seems to be getting way too complicated.  After reviewing the parts photo again, I believe this has nothing to do with any special router bits or even a router.
It appears that Bruce set up a stacked dado on his table saw or on a radial arm saw.  Set it for the maximum depth of the groove shown, which is on the inside of all of the uprights.  He set the dado to a bevel.  Placed each upright flat on his table saw at an angle to the dado using his miter gauge or a sliding fixture and a stop prevented the upright from going all the way through the dado blade.  That's how he gets the beveled, tapered, stopped groove.  It's the changing depth of the groove on two adjacent uprights that causes the shelf/slat to wedge in tight when inserted.  Just make the slat's sides a slightly different miter angle than what the uprights are mitered at.  Decrease it by a degree or so and that'll wedge it tight in the grooves.  The bevel angle on the slats and uprights match.  You could leave the miters the same as well, but I think the slats would come out a little too easy.  That's why I'm thinking that the miter angles should be mismatched by just a degree or so.
What do you think?
Very well could be, Ken - I took your theme and considered for a while.
I thought this joint would be such a pain to make by pretty much any means - the reality has to be reasonably easy to produce. It wouldn't be economical to sell this if it took as much detailed manual labor as we think the 'perfect way' would.
I adjusted my imaginary jig to 7/8ths dado width, which would hog out the area (and then some) taken up by the sloped walls. This would allow the shelf to fit but leave some small gaps. How unsightly would they really be? The shelves are going to be filled with dirt and plants.
It seems to work! The front-visible gap is at the bottom. The gap on top may not be very visible from the front because the void/gap is hidden inside the dado.
I'm starting the build on Monday. I'll start out prototyping this and change over to Dominoes if needed. (Though I need to make sure I have an assembly plan in that case.)
Some more images -
I don't understand why you would have a visible gap if you follow the method I outlined?  The dados hide the slight miter discrepancy between the slat and the uprights if you decide to do mismatched miter angles.
Hey Ken, I was thinking similar on tuning the fit with the miter angle.
If you look in the first picture in my last post, the box shape is the cutting path of my imaginary router bit. It follows a ramp that tapers the depth of cut. It's also tilted a bit,which I did to make it more closely match the "perfect" joint. (like the bevel in  your dado stack)
I don't have a table saw that could be used with a dado cutter, but could work up a router jig that would get it done. (Probably slower though)
IIRC, the walls of the dado are about 27 degrees from the bottom.
The width and shape of the kerf taken by the dado cutter on a table saw gives another clue. You could bevel it and get the walls close, but the floor wouldn't be right. The depth of cut would be too deep on one side. That floor issue wouldn't be very visible, though.
You could also cut the shoulders with the TS55 set on a bevel, and finish removing the waste with a router. The jig that holds the workpiece would be the same.
I cut the uprights today after making a pair of prototypes out of Fir. The test fit was promising and the spread between the legs at the ground is within a few mm of the Sketchup model. I'll do the cross braces before I start the process of dadoing the uprights.
Nice! Hope it goes well.
Post some pictures when you can.
Tim
Today I had a little road trip I had to make in the morning, but I got in a good 6 or 7 hours on the project today. I made all the half-lap joints today using the MFS. The learning curve was MUCH easier because of all the info posted by members here. I test fit the uprights with the cross braecs and the fit was NICE. I'm glad I took my time cutting the uprights because they're basically the backbone of the piece. I went to cut the cross braces and realized that I shouldn't have cut off 8 inches from that last cedar 2x4. I was short - damn.
I panicked, then remembered I had a cedar 2x4 left over from a project a few years ago. Whew, it was just long enough and even matched dimensions of the rest of the stock. my current stock.  I made more half-laps with the MFS and used a jigsaw to cut out the central interlocking half-lap joint. It was then that I threw away my good fortune of having the extra 2x4 because I cut out the wrong edge of one of the 2x4s. It caused the half-laps to be on the wrong side to mate with the uprights.
At this point it was getting late to run to the lumber yard, so I cut out the middle of the 2x4, cut a new piece to replace it, and tied the piece back together with 4 8x22x40 sipo dominoes. It's drying in the garage now. I'm not sure - maybe I'll just get another piece of cedar and re-cut it. What would FOG do? These cross-braces are covered with dirt once finished, so esthetics are less of a consideration than strength. I could also possibly drill a few pilot holes and drive a screw through each pair of domino joints?
Any advice on assembly methods? Domino and glue the uprights to the cross braces?
At the peak, where the four uprights meet - I have a ~2x2 block of cedar. I'm trying to figure out the best way to marry up the peaks of the uprights and this 'core'. Ken, if you're in the neighborhood again soon, this piece is something I may need a hand with - Was having a hard time getting a good piece nice and square on 4 sides for this. (After MFSing a lot today, maybe I can rig something up.)
Next step is to temporarily assemble the uprights to the base pieces and make a test shelf.
Leave it it should be fine. Like you say, you're covering it with dirt and this is a prototype.
I wouldn't do this. I would wait until I screwed up another piece of wood somewhere else (cause chances are I would) and then replace it.
Depends on what you want it to look like. For me I would just glue and screw it together as the original was.
Not sure I understand - what is the function of this 2x2 block of cedar?
Tim
Tim,
The block of cedar is the top cap to the uprights.
I'm in the area all week.  Talk with ya tomorrow.
Thanks Tim - I've been happy that I had few mistakes so far. Cedar IS very apt to tear out when routing if you're not careful.
The only 2x4 work left are the mitered base pieces. I'm going to wait on cutting those until final assembly.
The 2x2 is just the point where the uprights meet. I didn't want to have a pointy top. I needed a way to keep the inside of the top part of the pyramid open.
Awesome, also sending you an e-mail about that other project, Ken.
Here's an x-ray view of the top of the tower. Hmm, I need to figure out how to make the cap too.
