Festool Track Storage
ducmons
Gents,
N-B here, and relatively to woodworking.  Learning by trial and error, and I so wish I had more time to be on-line.  I have a small work area, space is at a premium. Curious what you guys use to store the Tracks when not in use. I know and end-cap opening on a bench would be the best, but I don't have the space to pull it out.  Need & welcome ideas.
You mean in workshop storage?
My 800 rail is hanging on the side of a wall cabinet(you can see the bottom of it on the pic), and my two LR32 1400 rails are hanging on the wall. Just an angled piece of wood with a domino sticking out of it.
That way they lean back just enough to stay put.
Thanks.  As I said, I'm a N-B.  [embarassed]  Maybe I've just had a few rough years and my brain isn't firing on all cylinders.
ducmons said:
Gents,
Welcome to the FOG!  [smile]
I have a shelf a few inches below the long side my bench / cutting table to store the 118" rail. So instead of pulling it out the end length wise it comes out the side, and can be placed right on the bench top where I need it.
ducmons said:
Gents,
[welcome] to The FOG,
My business is building a whole lot of custom cabinets. For plywood and sheet material miters and bevels, I use Festool TS55 and several guide rails.
As Seth told you, he has a shelf under his cutting bench on which he stores a 118" (3000mm) rail. Back in 2010 while my new large shop building in Burbank was being renovated, I had built an over-sized cutting table. To reduce waste, my primary material is 4x10 prefinished maple cabinet-grade plywood. These sheets require the 5000mm rail, the handling and storage of which can be a problem.
Therefore I had my cutting table made to accept a 4x18' sacrificial surface, so that below it there could be a shelf longer than 5000mm for the long rail. Below that is another shelf the same length on which I store 55" (1400mm) and 75" (1900mm) rails. On the other side of the table there are two similar long shelves, on which I store 2 of the 3000mm rails.
Having those rails parallel to the long side of the table makes handling them easy and very convenient. Because those rails only travel a few inches, they do not get banged up.
If my installers absolutely need to take a long rail to a site, it is the older of the 3000mm rails making the trip. I had a cloth carrying case maker in my neighborhood build one for the long rail, as well as one for the 75" rails. We use a standard Festool rail case for the 55" rails.
You said that you couldn't put it under a bench so this may not be of any help buy mine is under my mitersaw station.  I don't have the longer rail but I think I'd hang it on the wall if I did.
ccarrolladams said:
ducmons said:
Gents,
Great info!  Especially, since cabinetry is something I'm hoping to tackle. Can you share some pics with me?
I have the 3000 rail and use a bike lift to suspend it from the ceiling. I store the rail in the shipping crate which provides excellent support for the rail and also protects it.
[attachimg=#1]
Rail in its crate hanging from the ceiling.
[attachimg=#2]
Rail is lowered and ready to be pulled out and placed onto the cutting table. With this setup it is easy for one person to manuver the rail to the cutting position.
[attachimg=#3]
Rail being pulled out of its protective crate and being readied for use!
