surfmirrors
- Jan 26, 2010
Hello there,
I purchased my jigsaw about 4 months ago, i only cut 18mm birch ply with it.
I wonder what recommendations you have for setup with this tool, as i cant cut out one sheet without breaking at least 2 blades.
I am using the clean cut blades (thinnest possible) as i need a clean cut on entry and exit sides.
I broke 5 blades cutting one sheet, so at this rate (and it was 2 1/2 times more expensive than my Bosch jigsaw) i won't be able to afford to run it !!!
Over to you then,
Thanks,
Wayne
Over to you then,
Thanks,
Wayne
