presidentsdad
- Jan 15, 2019
Hey all, This is a follow up to a (slightly) older thread about aftermarket and Festool blades for the TS 75. The original thread is here:http://festoolownersgroup.com/festool-tools-accessories/aftermarket-blades-for-ts75-(list-of-part-numbers-with-specifications)/msg491112/
If I wanted three blades for my TS 75: A Rip Cut (mid teens teeth), Multipurpose (mid 30-ish teeth), and Fine Cut (50ish teeth) from Festool, I'd have to buy 2 extra blades (the Panther and the Fine Cross Cut) to the tune of about $219. Other than the cost, the only downside to that is that the kerf for the Panther blade is larger than the others. If I were to purchase, say Tenryu blades in an 18, 36 and 54 tooth variants, that would be about $177 (for the 3 blades), but the kerf on those three blades is very close (only 0.05 mm off - for cutting the splinter guard). Would this be a good idea to buy the Tenryu blades so that I can use the same rail for all three blades? Are the Tenryu's as good (or better) than the Festool blades? (A thought: Going with the Tenryu set could be less than $177 because I could sell the unused Festool blade that comes with the TS 75).
Appreciate any guidance y'all have to offer.
