Festool VECTURO
mstein4
I just purchased a new VECTURO.  How do I find the recommended speed settings for the blades used.  Also is there a good review available for the available blades and accessories?
Start at a low speed and increase for the best cut. There are to many variables for an accurate chart. Pine or oak will cut very differently.
Also rock the tool as you cut Unless your using the plunge base).
Both of the above saves blades---a lot.
Thanks for the Information.  One of the videos I saw said to use the speed as recommended on the blade by the manufacturer.
