bump said:corded sds drill.
i know they make a battery propelled version, however i want one with string on it that i can plug into the mains supply.
Kev said:bump said:corded sds drill.
[member=62762]bump[/member] I'm sure you'll be able to find a CHP45 Protool if you go hunting. I'm surprised we haven't seen the 25 and 45 re-released in green!
http://www.ebay.co.uk/itm/PROTOOL-B...Fachhandler-/131960895351?hash=item1eb97b7777:g:7gMAAMXQ6M5RX96u
rst said:Spiff, even worse it would probably be NAINA [mad]
Spiff said:rst said:Spiff, even worse it would probably be NAINA [mad]
Okay, I'll bite - what's a NAINA? [smile]
stoufferc said:My idea is simple. Make a circular saw that is specifically designed to cut dados and would ride on a track. The saw could be equipped with a 6" Fraud Dial A Dado type blade and would only have to cut up to an inch deep. The dado track saw would be used to cut perfect dados anywhere and to any length your track will allow. Having a dial a dado type blade would allow the perfect fit to any thickness material or plywood. Yes a router can be used to cut dados and I have used that process but a circular blade that scores the veneer with the outer teeth would leave a cleaner cut and would cut faster and could be completed in one pass. Yes router bits come in undersized plywood thickness but they are never perfect. And yes you can make two passes with a smaller router bit and a jig. I'm just saying that a track saw equipped with a blade make specifically for cutting dados would be really really cool!
Thoughts?
Craig
