Fill in the blank: I wish Festool made a ______!
  • Thread starter Thread starter Administrator_JSVN
  • Start date Start date
A DF600 that can do the full range of DF500 mortises  with the 10mm capable of being milled deeper like the 12mm, but keeping more or less to the same weight as the DF500.
Plus one on a 120v BS75 or BS105 with the later being preferred.
In regards to Festool releasing a “wife” as a product, my concern is that engineering will stick to the current strategy that  “user operational points” would be lime green colored.
The thing about the green function points is they aren't all green. The body release clip and the spindle lock button of the DF500 are both black. No clue why though?
I'd like to see a 2 to 1 adaptor with blast gate to connect 2 hoses (27 and 36) to a single port so you can just switch between them.
a DF600 that cuts a little deeper than DF500, and with a stepped stop feature like the one in DF700.
Max. weight: 7.5lb!
Max. weight: 7.5lb!
Sorry Chuck no stuffing the ballot box  [poke]  you've already voted.
With Festool's new CSC-SYS, this is something I hope will come soon.
Perfect when you are in the workshop and don't have to change batteries
"With Festool's new CSC-SYS, this is something I hope will come soon.
Perfect when you are in the workshop and don't have to change batteries."
It's doable now as [member=79804]Holmqvist[/member] showed. Greenlee introduced this years ago using the Makita 18V battery platform to run their crimp tools. A cord ran directly into the battery shell adapter and powered the tool just fine. Great to use while your batteries were charging, or if you were using it all day at the bench.
... would simply send me a tracking number instead of giving my email address to a third party who wants me to install their App on my phone. Please. It's important that I be able to track the arrival of expensive packages.
Brushless updated Domino
Brushless low profile updated RTS400
New polisher/buffer to replace discontinued Shinex
Corded Sawzaw
Corded tablesaw
New jointer/router table
I'd buy both instantly.
I'm trying to understand what is so significant about the brushless Domino? What would a brushless Domino do better or easier than a brushed Domino?
The brushless RTS already exists with the RTSC 400.
