Finished a roofing for a friend last month
Domi84
The gc did the framing. Would've been better if he didn't. The two white columns weren't supposed to be used but are now installed to push the roof back up so that the water drains... And to make life easy, nothing was square. Anyway, they are extremely happy with the result.
The little black above the door has yet to be installed by an ironworker and will match the color of the door.
First time i could use the ts55 and the router. Rails are a big timesaver!
duburban said:
What is this material?
Trespa. A low maintenance sheet product made of wood fibres. Inside is solid wood with resin. Outside is a durable layer available in various colors and patterns. These sheets run at €250 for 2,5mx1,8m sheet. So I measured a lot.
http://www.trespa.com/
