Finishing room -- how to cover shelves?
koenbro
My 3-car garage has a side room that is 6' x 15' with 8' ceiling. I intend to turn it into a painting/finishing room with a 4'x4' main surface. There are some shelves in this room that  I would like to keep, and cover them with plastic sheets. Right now I use regular painter's plastic that I lay over loosely and tape to the shelves, but would like something more permanent, that would still allow access to the shelves. All in all I have 6' of shelving on one end and 10' on the other (the former is a straight line, the latter is zig-zag). I am interested in something that would roll up and down easily and overlap a bit, or separate with a zipper or, preferably, magnets.
The zipwall.com estimator comes out at around $1300. Because i don't need a portable, flexible system with telescoping rods, and rapid setup and teardown, the zipwall might be an overkill. Is there any alternative you recommend --- shower-curtain like material I hang from ceiling or smth similar?
How about a set of spring loaded roll-up window shades that are overlapping a few inches.  You could easily attach them to the ceiling or the top of the shelves and pull them down when painting.  To help hold them in place, get some spring clamps and attach short lengths of 1x2 to them while they are down.
Wow slick set up with the curtain...thanks for the link.
Yes I too use the plastic and poles currently (rocker brand) but not the mag door
I've just stapled plastic sheeting drop clothes to the ceiling to create my spray booth. Then I just roll it up when not in use.  The problem I've had though is that as the finish accumulates on the plastic, when I go to roll it up the finish flakes off and makes a mess so the plastic needs to be replaced.  I'm going to try and figure out a system of ridgid panels that I can fold up somehow instead.
Yeah, I noticed the same. Already after one use there is some overspray on the sheets. But I think that is good -- the electrostatic charge on the sheets might attract the paint droplets which otherwise would cling to something more valuable. After a while just replace the sheets.
For now I have ordered a 70" wide by 8' tall spring-loaded thin plastic window blind from HD and try that out over the 6' shelf. Will take about 2 weeks for delivery, apparently.
Am considering stapling 4' wide x 8' long sheets of shower-curtain like plastic to the ceiling using 1" wide sticks, weigh them at the bottom with some other wood sticks, overlap a few inches, and roll them up somehow (eyelets on edges, and some string?) and replace occasionally.
