Here's my first solo project... an AV cabinet that replaces a combination of a too-shallow and too-short $14 target bookshelf and a cardboard box (to make up for the lack of height).  Most importantly, the power cables needed to be hidden, as we have a new cat that has decided that tangled messes of wires are great toys.
The body is BC plywood, with poplar for the face frame and the frame of the lower door. The rear wire channel is 1/4" MDF. Joinery is mostly unglued pocket holes. The only exception is the lower door, which used dowels and glue.
Finishing was a coat of shellac, then coats of semi-gloss latex paint until the can ran out. I got 2-3 coats on all the visible surfaces.
What I learned:
1. You can't really tell from the pictures, but the plywood did *not* finish well. The poplar I used for the face frame looked good after a single coat of paint. The plywood only looks semi-okay after three. There's little doubt in my mind that the extra cost for some good hardwood ply (or at least AC) will be more than worth it in time saved finishing. I went cheap because it was my first project and didn't want to waste good wood, but it was too frustrating to work with. Better stuff from now on.
2. I still need to work on both the precision and accuracy of my cuts. They weren't square enough (there are quite a few tiny gaps - although they're only noticeable up close), and there was about 1/4" variance in the shelf widths. I was able to mostly fix that, but this evening I invested in one of those flat tape measures, and I'll be picking up either a starrett or one of those '1281' squares this week.
3. The pocket holes seem to be holding just fine, but I'd definitely be more comfortable if they were glued up as well. Next time I'll glue up all the joints.
Favorite use of festool - Definitely a tie between:
1. Cutting some very thin strips of poplar to use as edge banding using the TS55+MFT
2. Using the C12 with the angle chuck + standard chuck to drill the hinge holes for the lower door after realizing there wasn't enough space to get the entire drill in. (Originally I was going to have the hinges on the side, but decided at the very end that since the door was so wide, i'd rather have the hinges along the bottom. It works great this way, I'm glad the C12 let me do it!)
I didn't think to take pictures during construction, but it's not like I did anything special. Here's the finished project. Once the exhaust fans come in, I'll be adding them to the enclosed bottom section, and the section with the game systems. Until then, I have a little desk fan for venting the systems, and have the external power supply on the lower shelf.
BIG thanks to everyone on this forum for all the helpful advice!
What I learned:
