E easty Member Joined Dec 29, 2021 Messages 9 Dec 31, 2021 #1 Is it possible for companys offering blade sharpening to flatten the top of the teeth on a Festool blade. ? like this offeringhttps://www.timbecon.com.au/torquata-flat-top-dado-saw-blades Rob
Cheese Member Joined Jan 16, 2015 Messages 12,697 Location Land of 11,842 Lakes Dec 31, 2021 #2 Forrest offers what they refer to as their #1 OD tooth style designed specifically for box & finger joints. https://www.forrestblades.com/saw-b...square-cut-box-and-finger-joints-40-teeth-en/
E easty Member Joined Dec 29, 2021 Messages 9 Dec 31, 2021 #3 The problem is though I need it for the TKS80 table saw which is a 254mm blade and 2.40 mm kerf and a 30mm hole. Rob
Cheese Member Joined Jan 16, 2015 Messages 12,697 Location Land of 11,842 Lakes Dec 31, 2021 #4 Well Rob, if you order the WW10401100 with a 30mm bore Forrest says the dimensions are: 10" OD..........254mm 30mm bore....30mm 3/32" kerf......2.38mm kerf I'd say that's close enough. [smile] They also offer this same blade in a 3.2mm kerf version...that's the one I own.
D Duckler Member Joined Jan 5, 2020 Messages 97 Dec 31, 2021 #5 I am sure my sharpening service (where i take stuff) could do that. Where are you located? easty said: Is it possible for companys offering blade sharpening to flatten the top of the teeth on a Festool blade. ? like this offeringhttps://www.timbecon.com.au/torquata-flat-top-dado-saw-blades Rob Click to expand...
E easty Member Joined Dec 29, 2021 Messages 9 Dec 31, 2021 #6 I'm located in Sydney Australia Thanks so much for the help Rob
