Frameless Mirror Medicine Cabinet question
kelauben
I'm looking to build a frameless mirror medicine cabinet and have a few questions.  The cabinet is pretty straight forward, but the frameless mirror is not.
Most pre made examples utilize european hinges for a frameless cabinet which is pretty straight forward, but how is the mirror attached to the door.  The hinges, Blum for example, need 13mm of depth in the door, so I'm assuming the mirror is mounted to a frame.
My question is, how is the mirror mounted to the frame?  Epoxy?
Thanks everyone.
Karl
You will probably need at least a 15 mm door for the drilling of the hinges then just
Stick the mirror to the door with silicone .we use something called mirrormate
You have to be carefull because normal silicone will eat through the  mirror backing
Just lay it flat stick the mirror then leave it over night .its best to paint the back and edges and 20 -30mm of the face first
What VW Mick said, don't use silicone; over time it ruins the mirror.  Look for any mirror mastic; made for exactly that.
If the mirror is sitting in a rabbet, don't forget to paint the rabbet or you'll see it in the mirror.
Frameless mirror with pivot hinges, glass shelves. Push to open magnetic latches.
I'll see if I can find pictures of a framed with Blum hinges.
