My question for this topic deals with electrical requirements for Festools. Below is the background story that has prompted me to ask this question.
STORY
I'm a hobbyist woodworker and DIYer. I recently purchased a TS55 REQ tofeed my Festool addic add to my growing collection of Festools. I love the saw and have nothing but good things to say about it.
However, while I was working the other day, the saw started acting weird. I was cutting 5/4 pine, and mid-way through my cuts, the saw started slowing down. I thought I was pushing too hard, so I slowed down, but the saw didn't pick up speed. This happened a few times. At the time, the saw was plugged into my CT MIDI, which was plugged into a 15A outlet. It didn't make sense to me that insufficient power from the outlet would slow the saw down mid-way through a cut (the saw would slow down right away, probably followed by a breaker trip, if insufficient power were the case, right?), but I decided to switch to a 20A outlet anyway. At first, this seemed to fix the problem. However, as I began my second-to-last cut (of course), the saw started for less than 1/2 second, then stopped...and wouldn't start again.
At first, I thought it had overheated or something, so I let it sit for about 30 minutes. Then I tried all kinds of combinations of Plug-It cords, dust collectors, straight outlets, tests with other tools, etc. to try to isolate the problem. Unfortunately, no matter what I did, the saw wouldn't start, thus isolating the problem at the saw.
I contacted Festool customer service right away. Fortunately, this has been my first experience with Festool customer service, and I am IMPRESSED. So impressed that I almost don't even care that the saw is broken. It will obviously be getting fixed, and I won't be paying for anything. Furthermore, I was able to talk to an intelligent human, and the shipping, both ways, is overnight on Festool's dime. If that's not great customer service, I don't know what is.
The person I talked to said the culprit is likely a problem with the saw speed controller. I guess we'll find out.
QUESTION
First of all, has this problem happened to anyone else?
Second, all of this got me thinking about the electrical requirements for Festools. The CT MIDI draws 1200 watts at max suction. The TS55 REQ also draws 1200 watts. My OF1400 draws 1400 watts. A Kapex (wish I could say "My Kapex...") draws 1600 watts. And according to the specs I've read, the power outlet on the CT MIDI is rated for up to 2400 watts.
In theory, a CT MIDI and attached tool could be drawing up to 3600 watts. In the US, at 120V, this is 30A. The largest commonly available outlet in the US that matches the plug on the US CT MIDI is 20A/2400 watts. My CT MIDI at max suction and OF1400 exceed this.
That said, I completed a huge routing project with the OF1400 and CT MIDI at max suction plugged into the 15A outlet I mentioned before. And it worked fine.
Do you guys commonly use 15A outlets and not worry about it? Do you turn the suction down? I can't imagine that with mobile craftsmen in mind, and recognizing that people may use extension cords, etc., Festool hasn't given some thought to this, but the tool spec numbers don't seem to support it.
Any thoughts? Is using a 15A outlet "hurting" my tools? Could I have inadvertently fried the speed controller by not providing enough power?
Thanks.
STORY
QUESTION
Thanks.
