dumbclub
- Aug 24, 2008
In my continuing effort to retire from 35 years as a studio furnituremaker, I recently sold two of my stationary sanders, so I no longer need this ductwork that connected them to my system.
It is industrial strength, 20-gauge spiral pipe and fittings, much heavier duty stuff than the longitudinal flex pipe normally offered by online woodworking shops. Being made of steel, there are none of the static charge issues that challenge plastic ductwork systems. Two of the pieces are regular 24-gauge, HVAC ductwork that I used to make the necessary attachment to the machines.
The straight pipe totals 18 feet in length, with the longest section measuring 65 inches. The 90-degree elbows are the preferred long sweep style for lowest airflow resistance. The 45-degree elbows are the smooth pinch weld type. The blast gates are full size, cast aluminum bodies with sliding steel shut-offs and can be removed from the 45 degree lateral tee if desired. All pieces are in clean, excellent condition, though some have a small amount of duct tape reside on the ends. All together, these pieces total well over $400 from places like Air Handling Systems.
Local pick up from or near my shop in Penland, NC would be great, but I'm happy to box it all up and ship by FedEx Ground. Delivery by me is also a possibility, depending on where you are and how quickly you need it.
Price: $130
*** SOLD***
NOTE:The second picture shows the ductwork when it was installed (back right corner).
[attachimg=2]
Price: $130
*** SOLD***
[attachimg=2]
