FS Rapid Clamp
linnlp12
Anyone know how to adjust the screw on the handle of the FS Rapid clamp?  I purchased one and no matter where the lever is set on the "gun" handle,  the metal block is too tight to allow the clamp to slide into the track channel.  The opposing piece fits ok.  I tried loosening the screw but it seems locked.  I didn't want to break anything. Hope the is a solution as I wanted to use it today.
I had to tighten mine after I got them, the handle that is used tighten them to the track, you will see a screw ( # 3 or 4 I think ) remove the screw and handle, there is a hex shaped nut under the handle, just rotate the handles position on the hex nut and reinstall the screw, give it a try and if you need more pressure rotate it more. Hope this helps, B
Did the trick, thanks for your help. The screw was in so tight I worried I would break something but it eventually loosened.
