- Nov 3, 2007
Festool has gained Full Unit HEPA Certification for their CT Dust Extractors!
If you have a CT 26 or CT 36 and are involved in RRP work on houses built before 1978 and are using practices that required a HEPA vacuum, you can now upgrade your CT to be fully compliant with the strictest standards FREE OF CHARGE! Fill out This Form and Festool will send you their updated HEPA filter and a copy of the certificate stating that your unit is compliant.
If you have a MINI or MIDI and currently have a HEPA filter, check to see if it says "HEPA" on the filter. If not, you need to get a new one, product number 496752.
You can download and/or print the certificate of compliance for a MIINI here and the cert' for a MIDI here.
Don't forget that you have to use the correct filter(s) for the certificate(s) to be valid.
