ear3
- Jul 24, 2014
Good choice.
Yeah, avoid the soft pad on anything where the sander will spend a significant amount of time off edge, as it will be more likely to roundover the workpiece. Other than contoured surfaces, I generally only use the soft pad when I'm worried of burning through something, like veneer -- and then I'm usually only using the 150/3.
L.Murphy said:Thanks again for all the information. I think I am going to go with the 5mm. I have a dewalt d26453. I'm not sure of the stroke size on that model, and it is discontinued. The newer dewalt variable speed ROS is listed as having a 3/32 stroke, which is roughly 3mm. I figure purchasing a 5mm will give me increased efficiency in lower grits if nothing else. It also leaves the door open for a purchase of 3mm Festool sander further down the line.
Follow up question-
Would you folks recommend the use of a "hard" backer pad for Table Tops? Softer Pads seem to be marketed as usefull for contoured surfaces.
