Cheese
- Jan 16, 2015
agehall said:Yeah, the RO150 was great for sanding down two sheets of construction plywood to a decent finish but once I was done in Rotex-mode, I found it very difficult to continue to a real fine finish in random orbit mode.
Because the Rotex mode is so aggressive, I'd try stepping back one grit level when going from Rotex mode to DA mode. If the last grit was 150 in Rotex mode, start with 120 in the DA mode and then go up from there.
Remember, the RO 150 has a 5 mm stroke so you'll probably not get as fine a finish as you would if you used a 3 mm stroke sander. The RO 125 has a 3.6 mm stroke and the ETS 125/DTS/RTS all have the smallest sanding stroke at 2 mm to give you fine/super fine sanding results.
