Tim Brennan
- Jul 28, 2013
Finally made the decision to put in the SWA cable to the shed. One of the electricians that has quoted me has recommended to install separate dual RCBO with enclosure to protect the circuit to the shed (materials required 25m tails x 2mm, 1 x Henley block and 16mm earth cable). He said that it would be best if the shed was on its own RCD because if the cable to the shed trips the RCD often then it will keep knocking out power to half the house.
Just wondering if this is really necessary.
