Birdhunter
- Jun 16, 2012
I've received a great deal of excellent information from this forum on building a bunch of outdoor benches out of Ipe.
I was researching glues for Ipe and I found an article in a July/August 2007 Fine Woodworking issue testing 6 different glues in 3 types of wood, each with tight, snug, and loose bridle joints. Each joint was scientifically tested to failure. The title is "How Strong Is Your Glue".
One of the 3 wood types was Ipe. The other 2 were white oak and hard maple.
The glues in order of success were Titebond III, T88 epoxy, Elmer's Carpenter's Glue, Old Brown liquid hide glue, Moser's hot hide glue, and Gorilla Glue. The average measured joint strength in pounds of pressure at failure for each glue in the above order were 2024, 1994, 1924, 1595, 1531, and 1164. So, Gorilla glue (in these tests) came in about 1/2 as strong as TB III.
There was very little difference in strength between TB III and T88 epoxy. The ease of use of TB III factored into the equation.
Based on this information, I plan to use TB III for the tenons as they will not be getting wet and epoxy on the areas that will get wet. I'll back up the critical glued areas with stainless steel screws.
