Michael Kellough
Never tried chilling the glue but wouldn’t the increase in viscosity be a drag?
jeffinsgf said:Packard said:You are suggesting that filling the slot at the ends of the domino will add strength?
I don’t see how it would. And of that gap were filled with glue, the PU would try to force the domino out of the slot making new demands on clamping.
Has anyone ever done testing on dominoes, dowels or tenons suggesting that PU offers greater strength than other glues?
If that gap causes weakness, then I should drill shallower holes for my dowels. I always leave about 1/8th of an inch gap at both ends of the dowels.
I suppose I should have said edges rather than ends. I am talking about the rounded edges of the mortise and the rounded edges of the Dominos not fitting tightly to each other. I think, with no empirical evidence, that polyurethane glue makes a better joint than PVA, and even if it is only as good... it is faster to spread, clamp and clean up.
I will agree that cleaning it off your hands is impossible. That's why I use gloves.
TSO_Products said:[member=7266]jeffinsgf[/member] - interesting topic - I wonder what actual problem led you to consider gap filling adhesive. Did you have some failures or did you see test results pointing to a weak and deficient joint? - any unusual requirements associated with your project?
Hans
Packard said:Dowels, biscuits, and I assume dominoes also, depend upon moisture to swell the components for a really tight fit. Water-based glues provide that moisture. I’m pretty sure that Gorilla glue is not water based.
So I wonder how much strength is sacrificed by giving up on the swelling of the dominoes that is lost by not using a water based glue.
jeffinsgf said:Packard said:Dowels, biscuits, and I assume dominoes also, depend upon moisture to swell the components for a really tight fit. Water-based glues provide that moisture. I’m pretty sure that Gorilla glue is not water based.
Poly needs moisture to cure...hence the recommendation to moisten at least one side of the joint. I thoroughly moistened the Dominos before inserting them. I'm pretty sure they expanded just as much as they would have with PVA.
TSO_Products said:[member=7266]jeffinsgf[/member] - If your looking at other high strength adhesive options, RESORCINOL can provide extremely strong connections PROVIDED the joint is close fitting. You might find it interesting from a strength standpoint. A two component systems (powder and liquid). can be used with heating during the assembly to speed up cure time. Open time is not unusually long at room temp. It is not designed to be gap filling - just ulra high strength structural wood connections. Unlike Epoxy, it is not affected by heat or sunlight UV exposure. Available through industrial supply sources only in my experience.
Hans
luvmytoolz said:TSO_Products said:[member=7266]jeffinsgf[/member] - If your looking at other high strength adhesive options, RESORCINOL can provide extremely strong connections PROVIDED the joint is close fitting. You might find it interesting from a strength standpoint. A two component systems (powder and liquid). can be used with heating during the assembly to speed up cure time. Open time is not unusually long at room temp. It is not designed to be gap filling - just ulra high strength structural wood connections. Unlike Epoxy, it is not affected by heat or sunlight UV exposure. Available through industrial supply sources only in my experience.
Hans
We used to use resorcinol for laminating F17 structural beams in the timber mill, really good adhesive, but leaves a very distinct brown line. Bugger to clean up once dried too.
