Greene and Greene Style Bed is FINISHED
stvrowe
The queen size Greene & Greene bed is now finished.  This is the first bed I have made and it is constructed of khaya and Gaboon ebony.  All I need now are the mattress & box spring.  There are 106 Dominos (90 structural) in this build ranging from 5mm through 14mm.  I also built a support structure to support the center of the slats to prevent mattress sagging.  The bed is sitting on some flooring scraps since the weight of the slats is insufficient to compress the carpet and pad under the support structure.  Once the mattress in installed, the blocks will be removed.
Bed next to nightstand built in Darrell Peart's Arched Aurora Nightstand class.
[attachimg=2]
Close-up of headboard showing ebony plugs and the faux through tenon
[attachimg=3]
Close-up of rail connection.  I used the Stafast bed-kit with two 14mm Dominos at each joint.  The Domino end entering the footboard and headboard legs have been sanded and lubricated with paraffin wax for ease of assembly/dis-assembly.  To prevent loss of the wrench, I used a 1/8" rare earth magnet pushed into a 7/64" hole in the side rail support.
[attachimg=4]
Closeup of slat to side rail connection to maintain position of slats.  I used 5mm Dominos inserted but not glued into the support rail for ease of replacement should it be necessary (they are hard enough to get out when not glued in place).  The slats were milled with the 6mm Domino cutter to provide some wiggle room for assembly/dis-assembly.
This came out really nice! Thanks for the pics and close-ups. I will have to add this to my favorites to reference later.
Very well done!!!  I especially like the cloud lift detail on the legs, too.  I also like the way you used dominoes to locate the slats.
[smile]
The stain used is Darrell Peart's formula using General Finishes dye.  It is 7 parts orange mixed with 4 parts medium brown.  I found out the hard way that spraying the dye yields much better results than brushing and takes a lot less time.  I sprayed the dye before I put in the ebony plugs.  The topcoats are garnet shellac.
Great looking bed.  You did a great job laying out the cloud lifts.  It is more art than science to get them proportioned and spaced so they look really right.
I like the idea of using dominos with the slats as you showed in the pictures
Nice!
Jay
Excellent job, Steve.
Do you happen to have plans available?  I'm about to embark on a similar project.  I seem to recall Woodsmith having a similar design, though not truly greene & greene!
Thanks for sharing.  Really like the domino technique for the slats.  I'll definitely borrow that idea!
neil
Steve,
Very nice work!  I really enjoy the Greene and Greene style, and you've done a great job adding in some of the G&G features!
Thanks for the compliments.  The mattress and low profile box spring was delivered today and this is looking too good to be in the guest room.  It might encourage guests to stay too long.  [big grin]
neilc - the only plans I have is for the headboard / footboard subassembly and after seeing this in real life size, I changed some of the dimensions before cutting the slats to final length.  I am getting ready to head to the IWF but, when I return I'll try to create a pdf of what I do have and share with those interested.  Send me a PM if interested but it may be several weeks before I get it done.
Steve
That is gorgeous! I'm afraid to show it to my wife because she'll want me to build one.
Any idea how many hours you have invested in that? I always underestimate how long things take...
I wasn't counting but started in May, working primarily 3 day weekends, took one off for a wedding, and 3 off for MBR remodel.  I do remember spending 3 full days making jigs & patterns.
