JakobProgsch
- Feb 25, 2016
So due to "reasons" I currently have both Festool TS (75 EBQ and 55 REBQ) and the Mafell MT 55 cc in my workshop. And one piece of information I was unable to find before having them all here was if it is possible to adjust them all to use the same guide rails. Obviously all three can use the Festool rails but the question was whether the blade position can be matched relative to the splinter guard. For the Festool saws the procedure is described in the supplemental manual (page 22). Similar to the TS 55 the Mafell has torx screws accessible from the bottom that allow some adjustment.
Sadly the TS 55R and even more so the MT 55 have very small ranges and I didn't manage to match them. The TS 55R at its farthest wants to cut closer to the rail than the MT 55 at its closest by a fraction of a millimeter. The TS 75 on the other hand has a fairly large adjustment range and can be easily matched to either of the other saws. It's also the easiest to adjust since all the screws are accessible from the top without lifting the saw from the rail.
I ended up matching the TS 75 and the MT 55 for now since those are the ones I use on rails and the TS 55R spends most of its time in the CMS module.
Maybe not the most exciting findings but I figured I'd document this as a data point since I wasn't able to find this information anywhere on the net.
