Two thoughts:
1 - what is a reasonable 'tolerance' for rip cuts for woodworking with sheet goods? In the case of DrD's measurements, .006 is about 2 sheets of paper thick. For case goods made with plywood or MDF and then sanded, planed, joined and put into an installation, what should we expect in tolerance for our work? I have and use a 6" digital caliper when running my planer and thicknessing. Not so much for sheet goods, however.
I have done some projects like my chessboard in the projects area that I hand planed to .001 tolerance. I've done metal lathe or milling machine work with a tolerance of .001 or higher on occasion. But on most woodwork, I don't get that close. And still strive for 'museum quality' in my work. Frankly, the finger can feel more of a difference than the eye can see sometimes.
2 - what should we expect for guide rails in terms of tolerance since they are extrusions through a die that may vary over time / with wear, etc. I wonder what Festool considers as agreeable tolerances? I found a book on extrusions and tolerances - http://www.aec.org/?page=lib_designmanual - but wonder what Festool considers acceptable.
