I've noticed that the EZ smart system has this really cool feature called "repeaters" I think. It has stops for the guide rails so that you can make a cut and slide the rails over so you can make another cut of the same exact width. This is for ripping not cross cutting.
Does the Festool system have a similar solution? Even though I can't see it being used often, I can still see it coming in handy every now and then.
Also what is Festools system for cutting dadoes to the exact width of the mating piece every time? I'd rather not set the guide rail cut then move and do it again for dadoes.
If you don't understand my second(or first) question, I will find a link of what I have in mind.
