Guide Rails with TS 75
Stone Message
Magazine/Blog Author
I am based in England and have joined this group after getting so much useful help by visiting as a guest - thank you everyone. I am new to Festool having just bought a Kapex 120, which is brilliant, and I am considering other purchases. I like the look of the TS 75 saw which I would buy with some guide rails. My concern is which guide rails to buy...
- I want to be able to cut along the length and width of 8' x 4' sheet material.
- I do not want to have to join guide rails (or un-join them) when switching between 4' and 8' cuts as time is precious.
- I do not mind joining 2 guide rails as a permanent arrangement if this has some benefit.
Now the question:
How much should I allow for the overhang of the guide rail at the start and end of any cut (ie how much longer than the board being cut should the guide rail be) and hence which guide rails should I buy?
Many thanks.
[welcome]to the fog
they reconmend the 3m rail for the 8foot cut with the ts75. and the 1900mm rail for the crosscuts.
if you can buy both and dont bother with the hassle of joining and un joining rails.
there is a thread lately that was dedicated to this subject
from what i read of what you ARE DOING I THINK (dont mean to start this debate going again) you need the ts 75 , a 55 might do you instead. do you need the extra capasity
I would get the FS1400mm  with the holes for the LR32 and the FS3000mm for the long sheet good cuts.
I have the 1400 and 1900 and really want a longer rail, because I need to plan my long cuts all at once so I don't have to keep putting the rails together and taking them back apart.
Here's my tip. When you buy the saw, you can pay the incremental difference and get a longer rail with it rather than the one it normally comes with.
You need a 5 inch overhang or so at each end of the rail, so 106" for a 8' sheet is the norm (FS 2700). Festool's own guidelines say that the 106" rail is good for cuts up to 100" but I think that is pushing it a bit.
Besides, welcome to the FOG!
For the TS75 and ripping plywood, best to go to the 3000 rail.
I use both the 55 & 75 and most of the time the 55 will do.  But when I have to cut 8/4 maple, the 75 comes out.  Would *not* want to use the 75 all the time, the 55 is so manageable it really is a pleasure to use.
My most used rail is the 1400' followed by the 1900 & 3000.
Welcome to FOG.
As others have already told you, with a TS55 nearly every user needs a rail at least 7" longer than the cut, so long as the material is only 3/4" (19mm) thick.
For that reason the standard guide rail included with a TS55 is 55" (1400mm) long. Join 2 of those together equals 110" (2800mm) which makes an 8' rip easier. The 2700mm rail with less over hang works, so long as the woodworker has enough practice.
Things get more complicated when using the TS75. It has a longer base. The TS75 is significantly heavier than the TS55 and most of us find the balance is different so that it is more accurate with much more over hang. The standard included guide rail for the TS75 is 75" (1900mm) The 118" (3000mm) guide rail allows 6" over hang at either end of an 8' cut, which many find the minimum for use with a TS75.
My first Festool plunge saw was the TS55. That same day I bought 2 extra 1400mm rails, which I normally kept joined for the rips and use the other 1400mm rail for the 48" cuts. For years I had no convenient way of transporting a 2700mm or 3000mm rail. My experience is that using the extra 1400mm rail I never had a problem aligning the connected pair.
Clearly it is easier to move a 3000mm rail from sheet to sheet than using a connected pair. Financially 2 extra 75" rails costs less than a 3000mm rail.
Obviously the larger TS75 needs longer rails than does the TS55. I own several TS55 and only one TS75, which I use for cutting sheet material thicker than 5/4" or 32mm. As soon as I had a way to transport longer rails I bought both a 2700mm and a 3000mm rail.
Each of us works in different ways, in different facilities and has different transportation issues.
I strongly suggest you search for discussion of the TS75 vs the TS55. Remember besides the difference in price of the saws, the TS75 will require longer and more expensive guide rails.
Now the question:
Many thanks.
Since you have been reading other threads you no doubt have read all the pros and cons and preferences until iyour head spins. But here is a straight forward layout on the needed lengths.
For the TS55 the 1400 rail is just enough to cross cut 48" but the 1900 makes life easier.
For the TS55 the 2700 rail will do the 96" cuts with enough overhang.
For the TS75 the 1400 rail is too short for 48" cuts. You need the 1900.
For the TS75 the 3000 rail is for the 96" cuts.
SRSemenza said:
Seth I like your straight forward approach to the thread a lot!
I just keep coming back to the issue that at some time everyone is going to need to take the track to a site location or into other rooms in the house to make a cut. When you move from a 1400 to a 1900 the transportation and storage issues are huge. Also if I was looking for a two dedicated rail (setups) to use on 48 cuts and 96 with that will also work better if you have to ever take them out of the shop and go to a site but also work better in a shop as they will not be too long and bang into stuff, I would IMHO offer the following suggestion.
One point I have not seen made on this tread is that the rail that overhangs sheet goods WILL deflect downward if it is not supported! I would never rest the full weight of the TS 55 or 75 on just rail that is extended off the sheet goods. The rail is just not that ridged. I would expect to bend a rail (more so with the TS75) and have the saw hit the ground if I were to set either the TS55 or 75 on just rail that extends any distance from the sheet goods and not be holding on to it.
I do find I want more rail extending on the end where I'm starting the cut than on the edge of end of the cut. Remember it is a Plunge saw so there is no need to start the cut with the leading edge of the TS 55 or 75 blade. As long as the back side of the blade is beyond the edge of the sheetgoods you are good to go!  On the other end of the cut once the front edge of the saw gets there I'm done.
I agree that For the TS55 the 1400 rail is enough to cross cut 48"!  I will also use the 1400 for my TS75, maybe I'm a bit more comfortable with the TS75 than a person new to it. For a bit more comfort... I would NOT go all the way to the 1900. A 1900 is too long to spin around the average shop and not bang it into stuff. I would rather have 2 - 800 for a 62 inch.
For the TS55 or 75 a 1080 + a 1400  rail will do the 96" cuts if you are comfortable with either saw. My recommendation would be use 2-1400 as that gives you just a bit more overhang (that as I stated before had it's own problems) but offers better storage and transportation options.
For the TS75 doing 48" cuts.  As stated about I will do it with a 1400 as I know my TS75....all too well. For more comfort I would rather have the above mentioned 2 - 800 for a 62 inch than go to anything longer.
Cheers,
Steve
i find the 1400 absolutly fine with the ts75 cutting 1220 and connect 2 together for cutting 2440 so 2800mm would do. I want a longer rail but can't justify the cost at the moment
My straight forward lengths are based on what is needed length  if not supporting the rail ends, if not plunge cutting, no deflector, not making a custom length, not joining two unless necessary, etc, etc, and what Stone Message specified in his question.
Basically placing rail  A, B, C, D etc on the wood and using A or B saw.
I have my own needs and preferences, which do not coincide with the lengths I suggested,  including a bunch of different factors.
I really think that starting with the base line lengths and then adjusting for personal set up and working methods is the only way to answer the question of rail length. Many, many of the posts in threads on this topic give the answer based on personal set ups, and methods. Those are good for demonstrating the possibilities and the factors to consider but tend to skew the answer to the needed length question.  ???
Stone Message asked his question on the Ask Festool board to get a basic answer, and not start another rail length debate thread.  Which means that I probably should not have even answered the question. I tried to give an answer with out all the add in factors muddying up the works. Sometimes I just can't help myself.  :-X
Seth is correct, in that there are many factors to take into account when figuring the length of rail you will need.  The best choice is one that is longer than the minimum.  If your rail is 'just' long enough for the task at hand, you will have to take extra care when placing your rail on the material so that it is at the proper location AND has enough overhang on either end.  Also, you will need to pay close attention as you get to the end of your cut so as not to run the saw too far -- the minimum length rail will require that you run the front edge of the saw past the end of the rail, yet stop just before the front gib runs off the end.  So, do yourself a favor and don't skimp on the guide rail.
