Alright, lets get the collective groan over with first, "Ugh, not another guide rail length discussion" [big grin]
I've followed/read a lot of discussions on longer guide rails, but haven't found much discussion on the shorter ones. I currently have a 75" and 55"-LR32. I've found I really like using the guide rails for cross cutting as well but 55" gets to be kinda long for that. I'm curious which people would suggest getting next, a 32" or 42"? Since my 55" already has the holes, I'd say getting the right length is more important than just getting a 42" so I can have the holes.
So what are people's thoughts? Which would you consider better, using a 55" to cover the range a 42" would be ideal for or using a 42" to cover the range a 32" is ideal for?
As far as my work environment. I don't currently have an MFT. I may break down and get one some day but it's going to be a while due to space constraints and other priorities. I only have a TS55 right now and primarily use it to cut down sheet goods but once in a while it gets used with "real" wood too. I suspect a Festool router or two will find their way into my shop in the next year so the guide rails will be getting used with those as some point.
Thanks for the input!
