hockey_magnet
- Nov 6, 2011
I was drilling a hole with my C15 - completely blind reaching under a sill plate and between floor joists with the 90 degree chuck. I was holding the drill in one hand and the chuck in the other. Anyway all was well until I heard a ringing grinding noise. I pulled the drill out and found that when I pulled the trigger, the grinding noise was present and while the drill was turning I could hold the chuck in one hand and the drill would stop turning but the motor was still running. I thought that something had stripped in the drill which is fairly new and hasn't been used much. Anyway I checked more closely and saw that the speed switch was halfway between 1 and 2. When I moved it into the 1 or 2 position, it ran fine -
Would running the drill like this cause any damage? Certainly I doubt it would be good for it? I also wonder why that switch wouldn't have a lockout - I quickly checked and found that the drill will run with the switch halfway which doesn't seem right to me. Any suggestions?
