So I came into a little extra money recently. After years of procrastination, and consternation about Festool being too expensive, I've decided stop resisting and allow assimilation.
I work mostly on cabinet stuff right in my shop (rarely work in the field). Also, I have a 3 HP cabinet saw, 8" jointer, 15" planer, VS drill press, 3 HP cyclone, and 19" Band Saw and a Festool MFT/3 and PS 300.
Given those "conditions," here's what I'm thinking about adding:
+ a TS 55 with 75" rail (in case I pick up a TS 75 later)
+ a 118" rail
+ parallel guide set
+ a CT 33 plus boom and handle (or should I wait for the CT 36? or even figure out a way to use my cyclone?)
+ an ETS 150/3 (or should I go with the 150/5 or Rotex?)
+ an OF 1400
+ a Domino of course
+ and various clamps and accessories
Through the benefit of experience, I've often advised folks with "If I had it to do all over again, I'd...." type comments. So, I'm interested to get your thoughts on the above items. Is there anything you would change or add? Obviously, I'll buy more later (sanders especially). I'm just looking to get a good start. Thanks.
+ a 118" rail
+ an OF 1400
