Bill Wyko
 - Mar 14, 2008
This is a staved turning I recently built. You may ask yourself "Self, how could Festool help in a turning?" Well, my HL850e is a huge help. Before you can even go to the table saw you need to have a jointed surface to get started. when segmenting, you have a number of segments which have to be mitered to precise dimensions. If the stick you start cutting segments from is even slightly tapered, you will have an egg for a ring. Therefore it's crucial to begin with true wood. I do have a Grizzly jointer but it always leaves about an inch or 2 of snipe at the end, my hl850e does not have this issue. at the end of the project I, again use my ETS125EQ sander on the vessel while it's spinning. This helps give you a smoother surface w/o getting the lines you get with sandpaper alone.
Now on to the vessel. It is comprised of Quilted Maple, Bubinga, Hard Maple, Tiger Maple, Bloodwood, a small coral inlace in the center of the knot and Walnut. The staves are cut at compound angles then the stripes are glued in between the staves. The stripes consist of Bubinga, Hard Maple and Walnut. Then 2 segmented rings are applied to the top and bottom of the staves. The next level up is a solid piece of Tiger Maple then a segmented ring of Bloodwood with 24 very small segments and the top ring of Bubinga. At the bottom, a solid piece of Walnut finishes it up. In all there are 113 individual pieces. It's finished with 4 coats of Minwax Tung oil. Here is a pic of it on the lathe and also completed. There's even a pic with it displayed on our tv console. Please enjoy and as always, comments are very welcome.
I appologize, I haven't taken pics with the inside finished. I actually make the inside as nice as the outside. I'll post pics of the inside tomorrow. Thanks.
