leakyroof
- Mar 23, 2011
. Oh, I'm fairly set in that dept. I bought the Mirka block to use with Abranet Abrasives. Great for sanding between clear finish coats of Varnish or Water based finishes. I cobbled together a hose adapter from Fein to fit the Mirka block connection and mate with the stock Festool AS hose.Peter Halle said:I have one of the HSK blocks which was a very generous gift from a member. Great product. I also have some Mirka blocks that I purchased from Woodcraft. They appear to be the same with possibly a slightly different hook and loop.
You can also take a look at Amazon: Amazon
I would have given Festool info but if not available here...
For what I use my Mirka block for, the Abranet is probably my best bet anyway. but thank you for the info. You know how it is. When it's NAINA stock, it's all the more desirable .... [wink]
