Home-built "MFT-XL" workbench
What a Cracking job! I sadly have to use my MFT/3 both in shop and on-site so I need the portability but if I ever have room
I would have one of those........ Top Job!  [smile]
Great job there, matches your workflow so will take your productivity to another level.
Out of interest, do the spacing on the dog holes for a MFT matter? What spacing did you choose between holes for this and what are they on the MFT?
Ali,
I do not believe that the grid spacing matters that much.  I haven't seen anything indication that 96mm is critical.  See my post two above yours (#19) for all the details.  Since I felt I just could not comfortably work with a full sheet of MDF as my workbench top, I knocked off a full foot from width and length (actually 13", since the MDF was a 49" X 97" sheet).  Since 36" and 84" are multiples of 4", that made sense for spacing.
I believe Ron Paulk used 3/4" holes on his workbench, and there are a lot of 3/4" benchtop accessories.  Also, watching his videos, he uses the holes primarily to drop clamps through, and therefore 3/4" versus 20mm is not much of a concern.  I watched is video on the fences (rails?) he adds to the long sides of the workbench, and I am going to add the same to mine.  I like the idea of cutting thru sacrificial boards to preserve the top.
My workbench top goals were twofold:  1) be compatible with the Festool/MFT "standard" as much as possible, since I am new to track saw usage and Festool, and 2) design for use with Qwas Dogs, which I purchased prior to building the bench.  (I had seen a several of Paul-Marcel's videos. and he convinced me I needed to buy them!) Having a Qwas Dog in hand prior to milling let me fine tune the milling to make the 20mm hole as near a perfect fit as possible.
I do have some Bessey 3/4" bench clamps with quick release clamping nuts, and they work great in the table, since 20mm is just slightly larger than 3/4". A snug fit is not needed,  so this package of clamps I've had for 5+ years finally got opened.  My other workbench had no bench dog holes.
I've looked around at all the 3rd party accessories offered by several FOG vendors, as well as woodworking stores like Lee Valley, and there are a lot of options out there for 20mm, as well as the 3/4" products that have been around for quite awhile.
Other uses:  I plan to use my workbench a lot as a clamping table for cutting/serving boards, picture frames, etc.  This is where I think the size will really be an asset.  I've also never had an outfeed table for my table saw, and this will make its use much simpler.  My next project will be a cart for my DeWalt planer that can be rolled up next to the workbench.  It currently uses the floor and a couple boards as an "outfeed table". I've been doing that way too long!
Finally, I appreciate all the positive comments.  I just ordered a TS55 REQ last night, so I am anxious to try everything out.   I guess I can put a list of Festool products in my sig line now ...
I decided to mount the MDF tabletop with some clips I've had laying around for quite some time.  Lee Valley carries them, and they are called "Table Mounting Clamps". They work great if you want to keep the top looking clean with no holes drilled for mounting screws. These do allow for movement of wood due to expansion and contraction, so they would typically be more functional for use with solid hardwood tops.
I used a biscuit joiner to cut the slots.
[attachthumb=#]
Clever use of your biscuit joiner...good reason for some guys to keep theirs after getting the domino.
Yeah, especially when you don't have a Domino yet!  I am new to Festool -- my TS55 REQ should be arriving on Monday.  I've already got a number of accessories for it. The Domino is next on the list.
Nice bench, I made one to the same dimensions 20 years ago with some left over redwood 4x4 and 2x6's and that size seems to work perfectly for assembly work.
I think you really enjoy the Domino when you get one.
Jack
Very nice table Lee. I'm a long time BT3 owner and would love to pick your brain in regards to how you mounted your saw to the table.
I use the Domino to cut slots for table clips.  [wink]
Welcome to the forum , mazmes  [smile]
