jrs said:
I am going to get a longer hose for my ct33, to help with clean-up.
I am currently using the 1" hose on the boom-arm (which only gives me about a five foot radius).
My questions are:
Should I go ahead and get a larger diameter hose? I am thinking yes, but not sure if it will actually make a difference given the pole.
If so, is the 2" one overkill?
Would the non-antistatic hose be sufficient for cleanup?
I will also use this hose for wet pickup (but with my fein vac, don't want to muck up the ct33!)
Yes, I would definitely get a larger-diameter hose, as it is less likely to clog with debris.
The Boom Arm shouldn't matter, but, since you are looking for more reach, you will either want a longer hose or just plug the hose directly into the vac without hanging from the Boom Arm. While your D27 hose is easily installed and removed within your Boom Arm's hose brackets, the larger D36 is a much tighter fit and may require you to loosen the screws on each bracket to install and remove -- a real pain. And the D50 is simply too large to fit within those brackets. But, you can always leave your current hose in place and strap a larger hose to the Boom Arm with velcro ties, or wrap large rubber bands around the hose hooking onto the cord hooks on either side of the brackets.
The largest D50 hose isn't really overkill, but the larger the hose, the less flexible it becomes. And, from what I understand, the non-antistatic hoses are more flexible than a comparable green antistatic version. Despite what has been stated in a post above, the D50 hose can and will work with the Festool vacuum accessories. First off, Festool offers both D36 and D50 accessories. The larger D50 series accessories are only for use with the D50 hose. But, the D36 series accessories can be used with any of the three sizes of hoses that Festool offers -- the D27 tool-end fitting fits
into the D36 accessories, the D36 tool-end fitting fits
over these accessories and the D50 hose requires the
Hose Reducer that will fit
into the D36 accessories. So, you can choose either of the larger hoses and still use your cleaning tools.
While I do recommend one stick with the antistatic hoses for tool use, a non-antistatic hose is perfectly acceptable for cleanup. I don't own a Fein, but the Festool vacs will also accept off-brand hoses that are the standard ShopVac size (2-1/4"). For messy wet pickup, I would suggest getting a cheap aftermarket hose that will fit your Fein and not spoil/soil a more expensive Festool hose...
