Michael Kellough said:He carves the parts, sometimes carving around the corner.
Michael Kellough said:It does add a little strength to the joint. Not enough to be worthwhile for ordinary cabinetmaking but he has a good reason to do this. (To be clear, this joint is less strong than using Dominos the usual way, at 45 degrees to both parts)
Using the finger jointed tenons at ninety degrees to one another allows the tenons to stay in the middle of the boards keeping them well below the finished surface of the part compared to the usual tenon reinforced miter joint which uses a tenon at 45
degrees to the part surface so the end of the tenons are just below the surface. He probably exposed one while carving...
I used to do it on a router table after cutting miters. Do all parts referencing from the same side, move the fence, repeat.Michael Kellough said:[member=15585]Svar[/member] How do you cut the mortises? Domino before the miters are cut?
Near the end of the video, he did comment on the puny-looking tenons and talked about making larger ones for DF700 cut mortises.IMHO, he is shorting the technique, by considering it a DF500 thing.
It'd be really fascinating if Festool released sales numbers and demographics on some of their tools like the Domino's.Sure, but there are a whole lot more plunge routers out there than DF700.
I would bet there are fewer than there are DF500.
I suspect that's highly valuable proprietary information. The competition would be willing to pay a lot of money for that - and I suspect they actually do hire consultants to try to gather that information for them. At least, that's what other high competitive businesses do, but I don't know about the woodworking equipment business.It'd be really fascinating if Festool released sales numbers and demographics on some of their tools like the Domino's.
