Sparktrician
- Dec 4, 2009
That's spectacular, Tom. Can't wait to see the final photos. Great job!!! [smile]
Alan G said:Looks great! Really like the niches!
Does the bench have conventional framing under the kerdi board or did you just used a thicker board?
Within the next year I will be doing some reno on our house. I have never used the kerdi system. Looking forward to giving it a try. I especially like the presloped pans. Doing a dry pack mortar bed with the proper slope and liners was keeping me up at night!
Alan G said:Okay great. Thanks for the info.
Yes. I will have access to the drain. How is the install and fitup of the kerdi drain?
Cheese said:Hey Tom, I noticed the niches do not incorporate Schluter corners and neither does the shower. Was this based on cost or based upon preference?
Michael Kellough said:Using the pre-sloped pan, what is the largest tile it will support?
May be showing my ignorance again but it seems to smaller tile should be used?
tjbnwi said:Michael Kellough said:Using the pre-sloped pan, what is the largest tile it will support?
If you don't want to do a lot of cutting and fitting, 2" x2" is about the limit to get the tile to follow the pitches well.
The pictured base is pre-sloped with 8x8's. Everything was laid out and cut to get the water to the drain.
tjbnwi said:When you get around to yours, post here, there are a lot of little tips that will help you through the install.
tjbnwi said:Cheese said:Hey Tom, I noticed the niches do not incorporate Schluter corners and neither does the shower. Was this based on cost or based upon preference?
Actually Tom I was referring to the Schluter decorative edging. I'm at the point where I can't decide if I should run it around the floor and in the corners of the shower or not. Each 8ft strip is about $30-$35, but each actual corner piece that connects the strips is $25-$35. The cost starts adding up in a hurry.
BJM9818 said:Wedi makes a similar caulk to Kerri fix. It’s about 1/2 the price. Only issue is it’s grey.
I just did a small 1/2 bath with All set. Not a big fan vs Ardex but it’s supposed to work on all aspects of a tile job.
tjbnwi said:Something others may run into and how I solve it.
The face of the niches were over 12" edge to edge. I bonded the glass to Kerdi, let it set, cut and installed.
Alan G said:tjbnwi said:Something others may run into and how I solve it.
Is that so it was a rigid piece and easier to install in a tight space?
