luvmytoolz
- May 17, 2021
Packard said:Sliding on the glue, which seems to have exceptional lubricity, is a problem I have experienced. An easy fix is one given to me from a old timer.
Before I apply the glue, I use a brad pusher to press into place a few very small wire brads on the glue surface. I then take an end nipper to trim those brads within 1/8” - 1/16” of the surface.
Those brads need to be placed in spots that are accessible to clamping pressure.
I apply the glue and position the mating piece. The sharp trimmed ends of the wire brads prevent the pieces from sliding. After the pieces are properly positioned, I clamp over the brads and over any additional places as required.
For applying trim, I place the brads as required. Smaller profiles need more frequent brads.
These brads are hidden and serve no joint function other than positioning. So even those purists who object to metal fasteners, can feel comfortable with this process.
That's exactly how I make my large door stop blocks. Saves so much time and effort, makes life so much easier!
