I am in the middle of making a few new Sysports and thought about how to make best use of the top. First I thought about a rubber top, but now I think a little MFT top could be more usefull for many tasks. I intend to use 19 mm MDF just like the MFT. I adapted the 95mm MFT grid to the size of the top and used the 20mm hole size.
Now I have two questions that you might be able to help with:
1. The Sysport is 1100 mm and for proper clamp use in the top holes you'll need almost 60mm of space underneath, therfore I could either raise the top by 60 mm or take the first Systainer out to make room. I tend to vote for the second solution, since the design looks much better and moving the Systainer is not a big deal. What's your thought or do you have a better idea for the top?
2. In some older post I read about using the MFT top as jig for routing the grid. I though about simply clamping the Sysport top to/ under the MFT and rout the holes with an edge trim bit. Have you used this method for routing your own MFT top?
