I've seen these split doors several times and have always been curious about how they are constructed. I suspect it's the same as the regular panel door, but the middle MDF panel is glued rather than floating. Is there anything more to this?
tjbnwi said:We do the split doors about 5% of the builds. We do glue the panel.
These a 1” thick due to the profile.
[attachimg=2]
Peter Halle said:tjbnwi said:We do the split doors about 5% of the builds. We do glue the panel.
[attachimg=2]
[member=4105]tjbnwi[/member] , great looking cabinets. Do you and your crew install the cabinets you build also? With the stacks of Systainers in the background I would suspect so.
Packard said:I do wonder how that latch works. Is there a secondary latch for one of the doors in the interior?
Also, I brought some archeological research in choosing my door hardware.
I did not build new cabinets, but rather I refaced the old ones and made new doors. I had the old doors to examine.
Everyone opens doors with the cabinet pulls. But they often close the cabinets by pressing against the door itself.
The old doors told the story. Instead of mounting all the cabinet pulls where the old ones were, I moved several of the pulls to the location where all the hand prints were.
So far it seems to be paying off. I would say nearly 100% my cabinet door closings are by use of the cabinet pulls.
The quarter turn latch that holds the split door closed would be used to open my cabinets. But almost certainly I would use the top rail to close them. With the light colored cabinets, my hand prints would show up in a hurry. That in reference to the charcoal gray cabinet above.
For the image in Misha’s O.P., I would end up closing the cabinets by pressing on the lower split rail.
In either case, the cabinets would look shop worn and shabby in a hurry, especially with the white and light colored cabinet.
I don’t think people give enough thought to cabinet hardware function.
