mastercabman
- Apr 15, 2007
you don't think that 3/16" is small enought?Steve Jones said:Scrap the router idea, any bit small enough will still leave a large gap between door/drawer fronts and frame.
Cut as much as possible with the TS75 (though you'd be slightly better off with the TS55 due to the smaller size blade)
the long cuts - take as close as you dare to the ends, I wouldn't bother with stops, you can just edge up to the end of each cut by sight.
Small cuts, even those drawer sides, I'd start with the TS55 anyway, line it up on the cut line with the center of the blade over the center of the cut line, then lower it to score the cut (you won't get all the way through, but you'll get a tidy cut in the surface)
You will then be able to finish all cuts with a jig saw, Festool has several zero set blades suitable. the long cuts just insert the blade (with saw off) move to the outside of the kerf slot (sanding the difference between kerfs will be easier on the outside edges) and continue to the corner.
To finish short cuts, place the jig saw toe-down onto the piece with the end of the blade in the slot left by the TS75 start at slow speed and gently tilt the saw to apply the blade to the bottom of the slot, move slowly forward while tilting more until you cut through, then continue to each corner.
The reason for scoring the short cuts with the TS is to give you a clean edge on those cuts. - It's a tricky job, but does a beautiful job wood with lots of character. Even someone who knows nothing about woodworking will appreciate the job.
what about the blade on the ts 55,how thick is the blade?
on the other,i would not build an inset style cabinet like that.
i would build it ,rail and stile.
for the look you after,i would do a full overlay and cut the drawers face from the sheet so that the grain mathes.
and i would edge tape/vener all sides.
