I have always found my RO-125 hard to control, so much so that I have probably never used enough to wear it in. I was using it recently to do the initial rough sanding and found that slight changes in where I applied the pressure; left, right, fore and aft, would affect how the sander moved over the wood. If the sander suddenly pushes hard in one direction, the natural response it to push back - but this then sets the sander off in another direction.
I suggest that you play around with subtly changing where you apply the pressure and see what affect that has.
With any of my sanders I find the control level is a function of (in no particular order):
- Grit
- Newness of grit
- Pad hardness
- Changes in surface grain of the wood (sometimes invisible)
- Vacuum suction
- Pressure applied
- Angle of pressure applied
In the case of the RO-125, the mode is also a big factor.
