I need a new putty
Kodi Crescent
To Hewey Lewis's "I need a new drug":
I need a new putty.
One that won't make me sick
One that won't give me walking pneumonia
Or that comes in a stick
I need a new putty
One that won't crack
One that if I sand it dry
Won't make me or my spouse hack
One I can stain or paint
One that that's not tough to use
One that is compatible with wood glues
One that I can use...
I've been using this Minwax putty, I forget the name.  It's kind of like Bondo (I think).  The last time I used this stuff without a respirator, I ended up with walking pneumonia (could be a coincidence).
I was sanding some recently without a respirator, and lo and behold I have some sort of respiratory problem now.
So I'm looking for a new putty/filler.  I don't have much experience with that Durham Rock Hard putty.  It seems a bit brittle.  What other options are available that won't require a hazmat suit to use?
This might be worth a look:  Timbermate
I started using this stuff last week and don't have much experience with it, but I think that you can do a search here and find more information.
Is that the two part Minwax filler? Yeah, sort of like Bondo. I really like the solid, very effective fill, and the drying time. But you are right ... resperator all the way. Nasty stuff.
Minwax high performance wood putty.  I like its characteristics, but yes, respirator for all work with it.
Thumbs up for Timbermate.  I've been using it for over a year and love it.  It's waterbased so if you need to thin it or if it drys out you just add some water.
I'll go buy some of that today and try it.  That Minwax is just too irritating to the respiratory system to continue to use.
I originally was using Famowood fillers but after a while they developed really off smells in the container. I've been using the Timbermate for about 8 months now and the product works great, only problem is the antibacterial agent they use in it has a unique odour and the smell is hard to get off your skin.
John
I use this. Works great on PVS trim out doors, filling nail holes on interior paint grade trim. I also have used it to fill hinge routes and latch plate routes when taking a single door frame and putting in a french door style. The door on my sig pic had a screen door at one time and I filled the hinge mortis, sanded and painted and they are gone. Inside the same door I removed an old deadbolt that mounts on the door and the trim was notched, I cut a piece of trim to fill the space then used this stuff to fill and sand, unless you are 3-6 inches you can't even tell with one coat of paint.
http://www.homedepot.com/h_d1/N-5yc1v/R-100398387/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
