leakyroof
- Mar 23, 2011
jacko9 said:. One more thought. Cut a 4 or 5mm slot with the Domino for your planned movement allowance. Fast and clean . The screw will look like you planned it all along once it's installed.Birdhunter said:Thanks.
I've got stainless steel screws, Titebond III, 8mm tenons for the Domino 700, and a plan of attack.
I even bought some premium pine 1X6 boards to build a prototype.
I'm still not sure how to attach the bench seat to the understructure so as to allow for movement. I've used Z-Clamps for the small tables I've built. I guess they would work for a bench.
I suspect that Ipe is not going to move too much but, if you drill a hole for the screws and then widen the hole to a slot on top with a rat tail file you get some room for movement.
Jack
