Domino size?
Redshift24
I am building a sofa frame that will have 8/4 walnut legs joined to either 6/4 or 8/4 x 4" rails. Which Domino size would be most appropriate? I'm assuming there will need to be multiple Dominos (4?) per joint. New Domino DF500 user here.
I'm with Jeff on this one. Once you get to 6/4 or thicker range, go with 10mm Dominos, since you are limited to the DF500. At 8/4, it might be worth it to drop down to 8mm and run 2 rows? They are also available in 50mm length.
I’m with JEFFINSGF. Anything less than a 14 is a risk for the joint breaking. I built a takedown king bed using the 700 connector system and it’s still totally solid after 8 years. Sometimes size matters.
Here's a page from the Festool book "Joinery Unmatched The DOMINO system user manual".
This is their suggested corner connection using 14 mm Dominos for tables or bedposts. I can't imagine that it'd be much different for a sofa.  [smile]
It's also interesting that in the same user manual under applications, Festool refers to "Lightweight rack (e.g. chairs) up to 10 mm Dominos."
[attachimg=2]
