Today I needed to process a lot of plywood for a roof renovation. I needed to produce around 200 plywood plates for use as wind wash blocking. I stacked sheets of 1/2" CDX plywood three thick, and used my TS55 with a Standard saw blade to gang-rip them into 12" rips, then set the flip-stop on my Sawhelper to 14.5", and gang-cut the plywood rips to length six at a time. WAAAAAY faster than trying to either rip the plywood on a tablesaw or chalking lines and ripping freehand, and cutting the rips to length went even faster on the Sawhelper because I didn't need to mark a single piece, and I was cutting six rips at a time. Even with the time spent getting my TS55 and Sawhelper out and set up I still saved a ton of time in the end. The job coordinator initially looked at me kinda fun for getting all of the equipment out, but he was smiling by the end when he saw how much time I saved.
In the past I've used my RO150 with a 24 grit Saphir pad to blend subfloors that aren't quite planing out properly. I've also used my TS55 to gang-cut 1/2" OSB in stacks of three for soffits in basements.
