I’m sorry if this is something that has been covered over and over but I cannot find the answer. I am making a skirt for a dining table and am trying to use my new domino 700 to make the cuts. This is only my second time using it so I still have no idea what I am doing with this machine.
The work piece is 2” wide, and 13/16” thick. The one tutorial I found for this size said to use the 8mm cutter and 40mm dominos, and the stop block at 10mm down . So I set the domino to 45 degrees, 10mm down, and 20mm deep cut... and cut all the way through the piece. So is there a guide for the settings? What did I do wrong here?
Thank you for the help!
